Old 08-02-2016, 09:10 AM   #11
jpc763
jpc763's Avatar
Got the call from the Indy.
AOS - Gone - $240 repair
60K Service + Tubes - $1200
Water Pump has play - recommend replacemnt - $1100
Also...
Tires need replacement $900 and alignment $240.
I am going with the top 3 and taking the tires up with the shop I got them at and enjoyed less than 10K miles on them. Warranty is 15-30k miles so we will see.
It seems reasonable. The water pump was a bit surprising. He said it is a 5 hour job and I will end up with a coolant flush too.
Should I see if he has the Low Temp Thermostat and replace that?
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
