Originally Posted by Slate 01
Give this a shot, I found this hack somewhere and it worked great.
Lower and raise the window three times, on that final raise, hold the switch in the up position for 5 seconds (after it has reached the full close position) before you release it.
It works, let us know how it goes.
Actually I tried this before and it did not make any change. The idea from what I had read was that it was a way to zero the starting or ending location of the windows.
So I guess in my guess is that I should start with the microswitches first? Is there a way to debug them in order? Any other links that you guys may have found useful if you had this problem?
