Passenger window does not come back up - goes down different distance
Hi, I have an issue with my car where the passenger window does not come back up after the door is open and closed...
The interesting thing is that if I use the inside handle then the door drops about 10 mm, which is the same as the driver side (whether inside or outside handle on driver side).
However if I use the outside handle the door drops about 25-30 mm, which is about 3 times more than from the inside handle.
Closing the door has no effect and the window stays in the open position...
Thoughts?
