There isn't a specific joint that needs to be checked, nor is there a reason anything should have came loose, except for a negligent mechanic. If you're worried, just check everything.
With most cars you actually need to tighten these types of joints with the suspension at ride-height to eliminate having the bushing pre-loaded under normal conditions that would lead to premature failure.
