Old 07-26-2016, 05:34 AM   #12
jeeper31
jeeper31's Avatar
Originally Posted by jcslocum View Post
If the inner and outer tie rod ends are tight, then you are looking at wear in the rack itself or the rack mounts. This is a system and you can chase/see what is loose as you go towards the steering wheel. You will need some help to get the wiggling and seeing done at the same time.
Good luck!
Thanks. If it's just one side can it be the rack? The drivers wheel is tight
jeeper31 is offline   Reply With Quote
