Old 07-26-2016, 04:01 AM   #11
jcslocum
Project Addicted
jcslocum's Avatar
If the inner and outer tie rod ends are tight, then you are looking at wear in the rack itself or the rack mounts. This is a system and you can chase/see what is loose as you go towards the steering wheel. You will need some help to get the wiggling and seeing done at the same time.
Good luck!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
