Old 07-25-2016, 09:47 PM   #10
DarkStar
DarkStar's Avatar
I was thinking about a resistor... Couldn't find any info tho even at work... Just relays and blower motors. But I was going to try replacing the relay... Where is the resistor? And I don't want you sending me anymore till I pay you for the Controls. Even tho it wasn't my problem, it's in perfect shape compared to mine, esp now my display has bled half through. And replacement LCDs are expensive. Unless you have a non working unit with a good display... I could send this one back to you instead since I'm sure it can help someone else who's controls are not functioning. Whereas I'm assuming mine are because yours didn't work for me but worked flawless in your car.
I also was going to test the blower however testing the plug for voltage at high speed, there was non. So fan can't work if nothing is powering it.
Sent from my SM-G925T using Tapatalk
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
