Pretty sure Joe will tell you to use anything which is both water & heat resistant. Sealant, tapes, whatever. Should do well. Not that this thing see daily 500kg of pressure or anything, although in your case I could be wrong lolll
Like I said before, be careful of (some) of the 3M products. Some of their adhesive are chemically activated (true bonding) and often only applicable for industrial use. If not removed before 72hrs you can kiss it goodbye, it's permanent. Just keep this in mind!
