Originally Posted by NickCats
When I brought my Box in for the 30k I found out I have a minor leak in the RMS. Dealer quoted $951. So $3000 for the RMS, clutch, and flywheel sounds about right.
Hope this helps...
Nick
Hi,
That's an awful quote! The Dealer is charging you to do both jobs separately, not combined. Yet, about 50% of the procedure is the same for each.
A local dealer charges $60(+parts) more to do the RMS when you have the clutch/flywheel done, and that's still charging an hour extra labor when it's a 5-10 min. job once the motor is opened up for the Clutch. That puts it around $2300.
It's unconscionable that so many Dealerships are such profiteers. This is something PCNA should look into. There should not be such varying prices for the same work. It's a racket pure and simple...
Happy Motoring!... Jim'99
