Snowflake never comes on unless I press snowflake button. If I hit auto, fan comes on at full speed setting, no heat or ac regardless of temp set or exterior temperature.
Heat comes on only when I put temp at high setting. And then it is so hot in the car after a couple of minutes I click it down to 85, and heat turns off.
If I set temp at 68 and hit auto, I get full speed fan with no ac or heat, doesn't matter if it's 35 or 85 outside.
AC comes on only when I hit snowflake button.
Nothing cycles automatically. I have to make any changes manually by pushing buttons.
Fan speed buttons work fine. It could be the temp sensor in the dash. I replaced it but didn't bench test the old or "new" one.
