Old 07-22-2016, 09:45 AM   #16
GatorLapis
Originally Posted by Luv2Box View Post
What all does the scanguage tell you?
It tells you all this...
The gauge and code reader will allow you to monitor intake air temp, water temp, mpg, battery voltage, throttle position sensor, fuel system loop status, cost per mile, gallons or liters per hour, ignition timing, engine loading, mph, and RPM.
It will also allow you to adjust the background color of the unit and scan/clear engine codes.
Check it out at ScanGaugeII : Linear Logic - Home of the ScanGauge
If you would like to trial it... the program is as follows:
Deposit 100 dollars to my paypal: ahflores@ufl.edu
I will send out a mounted unit that is plug and play for your car, trial it for a week and send it back. I will pay for shipping both ways plus I will refund you 70 dollars once I receive it. If you would like to keep it, just send me 50 dollars more and its yours forever!
GatorLapis is offline   Reply With Quote
