Originally Posted by jcslocum
I had issues with central locking and it came down to the little micro switches in the outer door handles. there are also switches in the in inner door handles. It can be a pain to figure out, but I suspect it's the outer door handle issue.
Does the window drop properly when the door is opened? It should drop about 3/8" or so when either handle is used.
Yep, the driver door does this but the passenger door doesn't. It only happens on the passenger door when I open it from the inside.
