Old 07-20-2016, 08:01 AM   #7
specboxCO
Originally Posted by catmanluge View Post
Has anuone had any luck shutting off their Thraction Control Completely??
I have tried several things but nothing has totally disarmed the TC..
The only way to 100% remove it is to swap in a non-TC ABS unit. The big problem is that the TC ABS unit is 4 channel, to allow separate braking to each rear wheel, whereas the non-TC unit is three channel, with a splitter in the rear brake lines. Not a huge issue, just join the rear lines together after the brake biasing valve and you are good to go.
There are no sensors you can eliminate with TC, it uses the wheel speed sensors to detect wheel spin to apply braking and cut throttle. If you eliminate those sensors ABS is gone too. PSM you can eliminate and keep ABS.
specboxCO is offline   Reply With Quote
