Old 07-20-2016, 04:52 AM   #18
CrisZenithBlue
CrisZenithBlue's Avatar
not sure of any other way to diagnose the AOS but the guys are right, when it starts to fail the diaphragm inside goes bad creating a vacuum leak and allowing oil to end up in the throttle body. both of those things can cause your idle issues.
think of it like this.. the AOS is a maintenance part, it normally goes bad after 60,000 miles. if you dont have a record of it being changed recently i suggest you do it as preventive maintenance which is never a bad thing on these cars, just like the water pump. an AOS is around 150$ get the part online (i recommend warehouse33auto.com, put rennlist in the cupon field for an additional 10% off, doesnt get cheaper than that), you get that to your mechanic and tell him to also clean your throttle body, check the MAF and give it a good spray down with MAF cleaner and you're doing a good thing for your car which will most likely solve your issue as well. it will run better and allow you to feel confident driving it hard.
CrisZenithBlue is offline   Reply With Quote
