Better brake pads ,fresh fluid and as much neg camber as you can get on the front end (then match rear to it) would be a start. I would also consider an upgraded oil pan metal baffle box.(I forget what the proper name is) because the engine is suspected of having oil pressure issues under high G cornering . Supposed to not be an issue without R comp tires but who knows for sure?
