Need some help please guys.
This morning after removing the key, it would not go back into the ignition, central locking wouldn't work and steering lock wouldn't engage, I bought a new ignition switch and fitted it this afternoon.
Now I can insert the key, start the car and remove the key without difficulty, but central locking and steering lock still don't work! Pressing the fob won't lock the car, nor open the rear boot (trunk), if I lock the car using the key, it locks the drivers door and the horn beeps once, the passenger door does not lock.
If I lock the car from the inside by pressing the lock button on the dash both doors lock.
The steering lock won't engage at all.
During the change of the ignition switch when I removed the old switch i heard the the steering lock activate as i removed the old ignition switch, and I was able to lock and unlocked the car with the fob, but only the one time. Once I installed the new switch and reassembled, the steering lock and fob lock stopped working again.
So to recap, I've installed a new switch and the central locking and steering lock don't work, I can insert, remove and start the car, but still dosn't feel right, I think it may be the barrel assembly itself as when I turn the key to position zero there is no click, I think the car still thinks the key is in the ignition so won't engage steering lock or central looking, this would also explain why it won't lock the passenger door when I lock manually with the key (safety feature so no one can be locked in the car?)
I assume I need a new barrel assembly/steering lock housing?
Buy Porsche Boxster (986 / 987 / 981) Boxster 986 2.7L 1999-02 Ignition Switch | Design 911 this one. Does this sound correct?
The car is garaged so its not a water/damp issue (under seat is dry) Fuses maybe? Help!
Any other explanations/ideas or help very gratefully received
