Originally Posted by Bebbetufs
Just finished buttoning up after checking the IMS and clutch. I changed pilot bearing, release fork and release bearing. I received the updated clutch fork and pivot pin.
Now there is no drive in any gear. Could it be the release fork is keeping the clutch partially depressed?
Guessing you got the wrong pivot pin, did it come from Pelican? Do you have the packaging with part number? If that's not the problem guessing improper fork install.
