I checked the three fuses listed as being part of the heat/AC system. All checked out with a continuity tester
But as I was power cycling the car the fans came on momentarily. I then discovered that if I turned the key back a fraction from the run position the fans came on and I could hit the snowflake button and the compressor would kick in and start cooling the cabin.
i feel points to my ignition switch as the culprit. I know these are a problem areas on these cars.
