Old 07-15-2016, 03:07 PM   #2
DRGETZ
Okinawa986
Service Mode for Glass Window Top
I feel your frustration as I just did this for the first time a few weeks ago to change air filter and belt.
This is what worked for me and my glass-windowed 2000S top...
1. Make sure the cables and attachments have been disconnected at the rear of the top as you will need the "slack".
2. Place a beach towel, blanket, or other protective covering over your roll bar to decrease the likelihood of the window scratching the painted roll bar.
3. Lower the top until it is just about even with the headrests (with stops in between - see Step 4).
4. Stop a couple of times in between the steering wheel and headrest to make sure nothing is pinching or still connected at the back end and to determine at what point the window will turn upside down when you lift the back part of the top up. After each stop, lift the back section while placing your other hand (underneath and inside) between the top of the rear window and your roll bar in order to prevent window from banging against the roll bar as well as to determine when you have enough slack in the top to push/pull the back section of the top high enough to remove storage compartment.
5. The weight of the glass won't allow the back section of the top to remain folded up without some help.
You could either prop it up or attach a bungee/rope to hold the bottom edge up if necessary.
I just used my elbow as I slid the [B]rear storage compartment[/B] and engine cover underneath the back section of the top. I found it easier to remove the carpet from the front after moving both seats fully forward.
Be careful when removing the storage unit as it has a loose metal bar beneath the "sliding doors".
Just lift up the storage compartment from the front and carefully pull out the thin metal bar before removing the rest of the plastic storage compartment.
6. Also be careful with the rear defrost wire. Try to locate its path before removing storage compartment, carpet, and engine cover to avoid damaging the connectors.
7. Make sure to re-attach/route the defrost wire, side connectors, and the rubber-lipped attachments at the bottom edge before attempting to close.
Replace the long narrow metal bar underneath the front edge of the storage compartment -- helps to prevent it from sliding on the carpet.
Good luck and hope this helps!
Respectfully,
Mitchell
2000 Boxster S
Zenith Blue
Black Top/Glass Window
Purchased May 2016
w/41.5k Miles
DRGETZ is offline   Reply With Quote
