Old 07-15-2016, 06:37 AM   #3
Smallblock454
Hi,
should work.
But always disconnect the car battery before doing any work on the passengers airbag – disconnecting and connecting. That is very important. Also remove the key from the ignition lock.
If the airbag isn't present you'll get a warning light in the dash. Also you'll get an DTC which can be erased later on via Durametric.
Regards, Markus
