Originally Posted by cornontherob
Hi all, recently, as I continued repairs on deer damage, I've had to replace my brake master cylinder and reservoir. At the moment, the brake pedal falls all the way to the floor, and provides zero braking power, even at little speed. Before I go through the process of bleeding this used master cylinder, is this normal? Should I buy a new OEM master cylinder instead? Or should I just bleed the brakes completely?
Buy new OEM or quality aftermarket. Then yes, you must bleed the brakes. It sometimes takes awhile, but stopping is worth it.
