This have happened to one guy we know here in SH (can’t find his vid now for some reason). He had genuine $1500/each BBS wheels on his bimmer. Residential CCTV concluded that the thief couldn’t complete his job and left the passenger side lugs just sitting on one thread (F & R wheels). Friend ended up losing one front. Just like you; mid speed, no warning, one second of wobbly’ing and ding-ding-ding off it went. Damage was incredible apparently because his locked and exploded in the footwell, passenger door couldn’t even open if I remember in his vid.
That’s what happen when you have 20” or 21” wheels I’m guessing
Side note Woody. No panic. Rotation of the wheel is the same as the thread lock pattern. Hence making it near impossible for lugs to unscrew, in fact it does quite the opposite. According to legends, the concept of “torquing” lug bolts is primarily to ensure that you do not ‘over-torque’ them, not the other way around – although also quite important lolll. Regardless, 99 cases on 100 of lug/hub documented failures were caused by over-torquing; cracking, stripping, etc, the internet has it all.
But here, I think you win something Woody. NEVER I’ve heard/read of even 4 (four) lugs unscrewing themselves in seconds. Are you dead sure all five were on the wheel before?? If there were only 2 then yes it could make sense that the wheel failed – but the only reason for that is only because you failed to install hub centric spacers, nothing to do with your meaningless 0.5mm thin silicon imo. Hub Centric Spacers => 10mm being a must man
For info Genuine Porsche wheel/hub design works with two lugs only. The 3 others lugs are for aesthetic loll
Ps . 8mm striping is 4 threads on a M14. X2 should have given you plenty, you really got unlucky there Woody :/ Don’t bother wasting money on lottery tickets, trust me on that one man!
Pps . I love wheels
