Old 06-25-2006, 11:32 AM   #10
MNBoxster
Originally Posted by NickCats
Jim,
Great info. Question for you, I recently brought my 99 Box in for the 30k. Dealer said that I have a very minor leak in the RMS but not to worry about it at this time but to keep that in mind. Garage floor has been clean with no evidence of leaking fluids. Due to the 30k miles, am I past the point of RMS "failure" though I may still have problems in the future ?
Hi,
Actually, no. You already have RMS failure, any leak, even a slight one, is a failure of the seal. This failure is most often progressive. How long you have until it gets much worse, no one can say, but it's never gonna stay static or get better - it will get worse and there's nothing you can do to mitigate the timeline.
That said, plan a budget now so you don't get smacked in the face with it when you least expect it. Also, I would try to ammortize the costs by factoring in a Clutch or Flywheel at the same time as the labor should be the same and only add a couple hundred to the existing cost. Even if you don't actually need it, it's better to throw away $150 worth of unused Clutch than to fork out another $600 in a year or so when the existing clutch finally wears out. That way, you'll get the most for your money. Hope this helps...
Happy Motoring!... Jim'99
