Old 07-08-2016, 06:41 AM   #16
JFP in PA
Originally Posted by dcs9654 View Post
New 2000 986 2.7 owner. Brought the boxster in for an oil leak. Received this estimate.
Re-seal valve cover gaskets and spark plug tubes, replace rear main seal, replace IMS with LN engineering 2 row ceramic (6yr-75k)bearing, replace clutch, release bearing and pilot bearing, replace engine oil and filter, replace air filter, replace serpentine belt, replace coolant, replace transmission oil, Check over for MSI and bulb replacement, Brake/clutch fluid flush, replace front strut upper bushings, bearings and bump stops, Check alignment.****
Total estimate ($5216.91)
Thoughts and guidance would be greatly appreciated!
Thanks!
I don't see that as being as far out of line as other do. We just finished an IMS Solution (dual row) installation on a 2001 car, which included a new clutch, pressure plate, throw out bearing, pilot bearing, RMS, new plugs, oil change, air filter, brake/clutch flush, and a couple of other minor updates; the parts bill alone was well over $3K and obviously does not take into account the labor hours to complete the job. So your estimate of $5K for even more work does not seem off base.
