Old 07-07-2016, 06:26 PM   #1
dcs9654
Repair Estimate Review
New 2000 986 2.7 owner. Brought the boxster in for an oil leak. Received this estimate.
Re-seal valve cover gaskets and spark plug tubes, replace rear main seal, replace IMS with LN engineering 2 row ceramic (6yr-75k)bearing, replace clutch, release bearing and pilot bearing, replace engine oil and filter, replace air filter, replace serpentine belt, replace coolant, replace transmission oil, Check over for MSI and bulb replacement, Brake/clutch fluid flush, replace front strut upper bushings, bearings and bump stops, Check alignment.****
Total estimate ($5216.91)
Thoughts and guidance would be greatly appreciated!
Thanks!
dcs9654 is offline   Reply With Quote
