Old 07-05-2016, 10:47 AM   #1
Gilles
You won't find fuel in this line, but it can become plugged with carbon from the EVAP canister, so blowing it out with compressed air is a good idea.
This should help you with were the connections are:
JFP, Thank you for the diagram!
Before blowing compressed air through the vent line (at the intake plenum end with the purge valve energized), I should first disconnect the other end of the hose at the EVAP canister (by # 9) to avoid damaging something else, right?
Thanks again!
