I purchased my 2001 "S" on Sunday June 5th and when it was delivered I changed out the serpentine belt, did an oil change, changed the fuel filter, cabin air filter, drained and refilled the 6 speed transaxle, replaced the center console with a great used piece. Installed 4 new oxygen sensors and a few days ago, had a LN Engineering IMSB kit installed, new pressure plate, disk, throw out bearing, front motor mount along with a new coolant tank and cap. I'm waiting for spark plugs and spark plug tubes to arrived and while I have my car on my lift I'm going to have the rotors turned and replace the brake fluid. Today I removed the MAF and used some of that MAF spray cleaner then re-installed that piece. I had no maintenance records so basically I'm doing a 60,000 service and know that it's done.
