Old 07-01-2016, 08:01 PM   #3
KevinH1990
KevinH1990's Avatar
Porsche Boxster 996 Gauge Cluster Upgrade - 986 / 987 (1997-08) - Pelican Parts Technical Article
Porsche Boxster On Board Computer (OBC) Upgrade and Turn Signal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
The only difference in the S and non-S cluster is the trim rings. The analog speedometer may show a higher top speed. Although the standard Boxster cluster is white numerals on black faces, you could order the black on silver (it appears white but it is silver) as an option in the non-S cars.
I've posted links to two articles on Pelican that I found to be very good sources of information. The second one shows how to upgrade the cluster you have to activate the OBC.
Good luck with your project.
