Old 07-01-2016, 06:44 PM   #15
JFP in PA
Originally Posted by Luv2Box View Post
I recall we went through this argument about pressurized fluid changing systems before and someone proved it can be done and provided links to the equipment to do it so perhaps if you use the search feature here you'll find it. Having to change your trans fluid three or four times to get "new" fluid in is ludicrous.
I believe you recall incorrectly. This is the layout for the transmission cooling system as used on the Boxster Tiptronics. All of the lines in the diagram are coolant or vacuum lines, none carry transmission fluid, making it impossible to connect a true pressure flushing system to the Tip and push out the old fluid with the car assembled (you can barely even see the cooler on the car, much less get at it to connect anything, and there are no external pressure ports on the gear box) :
Over the years, several companies have claimed to have developed a pressure flushing system, all of which turned out to actually be exchange systems, which mixed the old and new fluids during the process, making it inefficient.
