Old 07-01-2016, 03:50 AM   #18
CrisZenithBlue
CrisZenithBlue's Avatar
Originally Posted by flewis99 View Post
Can anyone help me with my 1997 Boxster? The top is down, I have 2 broken plastic ends a loud thumping every time I try and raise the top, and the top will now not come up for anything. The clam shell is shut tight and can not be maneuvered in any way to get to the cloth top to try and manually pull it back. I read that if I could release the shock absorber that it would release the clam shell, but how in the heck do you get to the shocks? Desperate..
Go to your owners manual it explains exactly how to release the rods on he clamshell and top. You basically have to pop them out using a pointy sharp tool that you have in your tool set that came with the car, it's the long aluminum one. If the top is down its the easiest way to pop then out. Once you do that you can move the clamshell and top freely and then you can start fixing it
CrisZenithBlue is offline   Reply With Quote
