Did the computer under the drivers seat get wet?
That computer could be expensive. When water gets in a Boxster from clogged drain plugs (check those too), the water pools under the seat and can kill the computer.
The plastic rear window can be repaired if the top fabric is OK. If you don't find a shop that does car tops, look for an upholstery shop that specializes in boats since they do a lot of plastic work.
