You may be able to stick a small flat head screw driver in between the levers. There is a little wheel with teeth on it. You have to turn the wheel to release the levers. If this doesn't work you can take the whole cover off. There are two allen head bolts holding it on. Look for the two holes on the side next to the seat. Once you have the cover off you can see the wheel thing I am talking about.
