Old 06-27-2016, 12:32 PM   #1
germaneighter
FS: 2002 Boxster Base 5 Spd Oklahoma $6,500
Approx 155K miles
Runs very well.
Oil changed often -- Mobil 1.
Oil filter cut apart at every oil change -- never any metal bits.
Since I've owned the car (last 5 years) I've replaced the following items:
Alternator
Battery
Air/Oil Separator
Plugs
Coolant Overflow Tank
Water Pump
Clutch about 10K ago.
Brakes
Rotors
Tires (KUMHO ECSTA ASX)
Beluga SS sport exhaust. (I also have the stock muffler. It is unbelievably easy to change out.)
I was backed into on the front bumper cover a year or so back so I replaced it with an aftermarket urethane cover that I think makes the car look a little more aggressive. (I also have the original bumper which could easily be repaired)
This is my daily driver. I put about 65 miles a day on it, (mostly highway). I tracked it at Hallett once in July of 2015.
Things that should be fixed:
Soft top material is good but rear window is yellowed and has some small cracks.
Starter bushing whines sometimes – usually when starting cold or in cold weather.
Remote keys stopped working about 3 years ago….
The alarm, door locks, and auto window retractors all have some gremlins. (most are related to micro switches in the inner & outer door handles) Power windows work great. It’s the retractor that pulls the window down slightly to clear the weather seal when the door is opened.
If I don't do anything to it the price is $6,500
If I start fixing the minor issues - my cost for the parts & labor will be added on.
germaneighter is offline   Reply With Quote
