Old 06-27-2016, 09:15 AM   #2
jvfante
Santa Barbara, CA
I've chased this intermittent stall or hesitation issue on my '98 2.5L MT 138k Boxster for several months and replaced all the usual items myself: plugs, coils, MAF, O2 sensors, fuel filter, cleaned Throttle body & checked fuel pressure. The car ran great, but still had the occasional hiccups when accelerating.
In desperation, I took the car to a local indie shop and then to the Santa Barbara P- dealer and neither of them (and their fancy machines) could figure it out. They did take my money though and wanted another 4 hours to check my wiring....
Then, thanks to a suggestion to check for vacuum leaks from "itsnotanova" (via his Plano, TX Porsche dealer), I found the culprit to be a slight leak at the coupling between the top breather hose and the AOS. I fixed the leak and the hesitation is no more.
Many thanks to Woody & the guys in Plano.
jvfante is offline   Reply With Quote
