Old 06-26-2016, 01:08 PM   #10
SilverSSS
You are not making an oil PAN gasket. You are making a cover gasket. The pan as on V-8 engines will hold, with some leakage, the entire capacity of oil in the engine even if it becomes loose. Where as a loose cover on the boxer engine could allow the entire oil volume to leak out. How many times have you seen a valve cover with the bolts finger tight? IMHO not a good idea.
OH and not to mention altering the highly important Oil pump pickup to sump clearance.
This is something to think about. think i will go with RTV. The problem with RTV is simply ease of installation. Reassembly on your back in a cramped space is not fun. Not to mention the gooping into the pan problem.
SilverSSS is offline   Reply With Quote
