Old 06-24-2016, 12:00 AM   #885
particlewave
Only chance you have of finding one of those is off a boxster that doesn't see much daylight. Down here in Texas, that rubber piece is either broken off or turns into a tar like substance. Nobody sells them new either I took them off mine and it really isn't that noticeable.
Frost King double D self adhesive foam rubber. Cut the arch portion off of one of the "D"s to make it a "p" strip. Works decent
This picture is deceptive...the two "D" strips are actually connected (you have to tear or cut them to seperate). Just don't seperate them and cut the arch off one of the strips so you have more surface area for adhesion and place it so that the remaining "D" is at the rim of the headlight.
