Old 06-22-2016, 10:24 AM   #1
Fyeganeh
Fyeganeh's Avatar
Well it sounds like it's a rare event - I guess they are better designed than water pumps. Reading online I found the following symptoms for a failing oil pump:
"The symptoms of a bad oil pump are many, and some of them include abnormally noisy hydraulic lifters, valve train noise, a higher operating temperature in the engine, a decrease in the oil pressure of the car and a noise in the oil pump. An oil pump is one of the components of a car that does not require frequent servicing and repairs, but when it fails, it can cause catastrophic impact on the performance of the car."
I've seen repeated posts here about lifters failing and higher oil temps.
I've also seen posts about replacing base boxster oil coolers / heat exchangers with larger boxster S coolers. Would this increase resistance, lower pressures and cause more failures? Are there more lifter failures in boxster S than a base boxster?
Fyeganeh is offline   Reply With Quote
