Old 06-22-2016, 08:01 AM   #41
Smallblock454
Hello CrisZenithBlue,
i think the idea is not to have a list what should be replaced. The idea is more what should be checked and replaced if it's out of specs.
That is why i said you can only do an estimate if the engine is disassembled and everything is measured and given an opinion of.
Has to be checked:
- hydraulic lifters
- all plastic chain ramps (in general it makes sense to replace them all)
- all chains (length)
- IMS bearing, IMS tube and everything connected to the IMS
- Vario cam system
- valves, valve springs, valve seats, cylinder heads
- sparks (in general it makes sense to replace them all)
- spark cables
- ignition coils (in general it makes sense to replace them all)
- cylinders (roundness has to be checked also also if the coating has be harmed by metal). If they are not 100% round you have to decide what to do.
- pistons (roundness, marks)
- piston rings
- rod bearings
- crankshaft bearings
- if oil is in the cooling system, the complete system has to be cleaned and it is better to replace radiators, hoses and the air / oil cooler, because oil eats rubber
- all engine parts have to be washed, cleaned and checked
- all connectors and hoses
- AOS; makes sense to replace
- all filters, oils and coolants
- sealings must all be replaced, and a lot of rods and screws must also be replaced
- clutch and dual mass flywheel has to be checked
- also it is useful to check oil pump, water pump, generator, climate compressor, starter…
The list is even longer and i'm shure i forgot something. Before you have a complete diagnosis you can't say what to do.
In general: everything that has caused the problem must be replaced. Everything that is worn out of specs should be replaced.
I you are looking for a replacement engine, what makes shure that this engine hadn't major problems before?
Not an easy decision. Hope that helps.
Regards, Markus
Smallblock454 is online now   Reply With Quote
