Try resetting the window. Run the window all the way down and then run it up until it stops and hold the button for 5 seconds. Do each window separately. The system sometimes needs to be reset.
The windows are supposed to drop +/-4 inches when you start to open the top. There are switches in the top latch, brake handle, inside and outside door handles plus the dash switch to operate the top. German engineering running wild.
