Thread: Exhaust Rattle
Old 06-20-2016, 11:35 AM   #5
Smallblock454
I can't see from the photo which material the exhaust is. I would say you need somebody who can weld the broken parts together, but you have to check first which welding type is possible and if it is possible. Exhaust has to be removed. Welded seams need to be cleaned, so there is no rust and then the parts has to be rewelded.
Else you have to buy new exhaust tips. But i don't know which ones will fit to your exhaust. You have to measure everything; especially the diameter of the connector pipes. Can't see from the picture if the exhaust tip is welded or clamped to the silencer.
Regards, Markus
