Old 06-20-2016, 06:17 AM   #12
Racer Boy
Racer Boy
Racer Boy's Avatar
I doubt if it's the sway bar bushings. It's most likely something to do with locating the wheels under torque, which would point to the rear trailing arms. Those are the arms that bolt to the body behind the firewall.
It could also be tires, but you didn't say that you had changed anything around that. You might try taking the spacers out from the wheels and see if that makes a difference.
Lastly, it could be a bad alignment. Did the shop give you the specs? The toe could be way off.
