The engine is probably hanging on the trans shaft. The back of the engine must be supported or jacked up a little bit. The engine only has 1 support spot at the very front when the trans is pulled.
When I did the clutch IMS last fall, I made a small bracket to support the engine when the trans was out. You can see the trans is still in place as the bracket needs to keep the engine in a good position.
