I'm going to head out and check everything shortly. I had a thought and did some research last night. Given the fact I installed the "S" suspension my sway bar sizes changed. I ordered 19.8mm bushings for the rear and recall them seeming a bit to not fit the way I though they should. I can't recall what I put on the rear size wise. Last night on Pelican I saw it actually calls for 19.2mm. I ordered them and they will be hater later this week
My question...if the rear bushings are the wrong size could that cause it?
