Hi JayG,
how did you bleed the clutch? Did you use a under pressure system? If yes how much pressure did you use? Did you first bleed the brakes lines in the sequence from the longest way to the brake cylinder to the shortest and than the clutch?
If you didn't use that sequence or if you didn't use an underpressure system, try to bleed the system again. Don't use too much pressure.
If you get a good clutch everything might be OK, else don't track the car and diagnose the cause for the failing clutch first.
Regards, Markus
