Old 06-17-2016, 07:54 AM   #2
911monty
911monty's Avatar
Unfortunately, yes this is normal. If you remove the inner fender well lining you will see a plastic cover behind the fans that directs the air downward. If you look from below you will see the fan resistors in these outlets. There are air guides that help to deflect the air outward from under the car, but don't deflect all of it.
