Thread: Purge valve
Old 06-16-2016, 10:44 AM   #1
Gilles
Originally Posted by ftp19601960 View Post
Barbed union for 3/8 nylon fuel line, 5/16 rubber fuel line piece. Apparently you need to remove purge valve assembly before (I managed to do without intake unbolting). Next time the valve can be replaced much faster. I have clamps from both ends.
FTP: you wrote that you installed (5/16 or 3/8..?) rubber fuel line.
Please note that you MUST use the appropriate "Metric sized Fuel Injected Rated" fuel hose, otherwise the SAE sized fuel hose will eventually fail and you will end with a high fire hazard
I am not sure the diameter but on the Alfa Romeo & Fiat (Bosch FI) the fuel hose is a 7.5mm diameter
