The codes (P0410 and P1411) indicate that the secondary air pump is either not working, the lines are plugged, the change over valve is inoperative, or you have a vacuum leak in the system.
Time for some more intensive diagnostic's, starting with the secondary air injection system.
Ouch! Doesn't sound very simple. So the fact that there is a new air pump??? I assume that is different from a "secondary" air pump?????
