Old 06-13-2016, 02:17 PM   #10
JFP in PA
Originally Posted by vdoman_pro View Post
Thanks for the responses everyone. JFP, yes my battery is disconnected, and I just checked the continuity between the positive and ground cable and it's good. The shorting out happened after I uninstalled and re-I stalled the starter. According to this test, the starter is installed correctly. Any thoughts.
My point was that if you have continutiy between the postive cable and ground, you have a continuous dead short in the system, which is not good. You need to now isolate that short.
