Old 06-12-2016, 07:38 AM   #13
Smallblock454
Hello John,
if you would have the option to test the light with a standard headlight, i think that would be the easiest way to test, because than you could easily see if the light works.
If a standard headlight doesn't work, it's more a light switch, relay or connection problem. But i'm pretty shure a standard headlight will work.
If a standard headlight works, it's a ballast or a power (ampere) / connection problem.
Hope that helps
Regards, Markus
