Originally Posted by Smallblock454
Hello,
first: did you check the fuses? I don't know how it's wired, but i would check fuses first.
I don't know this system wiring in detail, but does this system use a resistor or a can-bus adapter? If yes, that was what i would inspect first. Because both sides don't work i don't think it's a ballast problem, but depends on how it's wired.
I don't think it's a headlight switch problem.
Regards, Markus
If it was a fuse problem, would the HID's *try* to fire?
